Neue Firmware für das GPSmap 60CSx ist da
Neue Firmware Version 3.5 für das GPSmap 60CSx ist bei Garmin erschienen.
Change History Version 3.30 to 3.50:
1.  Change number of lines of text in the address field on map feature review page from 4 to 6.
2.  Improve robustness when recovering from a partial map load.
3.  Limit number of custom POI bitmaps to 64 to ensure enough memory resources. Bitmaps beyond 64 will show the default custom POI symbol.
4.  Added better compatibility with Mac computers in USB mass storage mode.
5.  Improved pedestrian route calculation for shortest distance method.
6.  Added ability to recalculate a direct goto route.
7.  Fix issue where MPC maps would use excess file handles and potentially cause a shutdown.
8.  Address issue where nearest points search would skip some points.
9.  Changed datum used in the the SWEREF 99TM grid to GRS80.
10. Changed datum used in the the Estonian grid to GRS80.
11. Fix potential shutdown when using TOPO West 1999.
12. Fix potential shutdown on track setup for data card when track log files have long file names.
13. Corrected French translation for "Log track points".
14. Improved promptness of the turn review popup.
15. Improve track log recording for sensor products to continue recording sensor data even when GPS doesn’t have a fix.
16. Fix potential shutdown when propagating in a cul-de-sac across a map boundary.
17. Added more time zones.
18. Fix potential shutdown when clearing recent find list when custom POI with custom bitmaps are in the list.
19. Add A905/D900 unlock code communication protocol.
20. Make route recalculation on MPC maps behave like City Navigator maps.
21. Remove lithium ion as a battery choice. For 76x add lithium battery choice. Lithium ion batteries have a voltage that is too high and might damage the unit.
Hier der Download Link
Hab soeben das Firmware Update aufs GPS Gerät geladen.
Das UPDATE lief problemlos ab.
Das GPS Gerät scheint einwandfrei zu funktionieren.
Sehr wichtig ist ein Update wenn man die Firmeware Version 3.1 auf dem GPSmap 60CSx drauf hat.
Diese fehlerhafte Version 3.10 zeigt eine falsche Postion beim Schweizer Koordinatensystem an. Schlicht unbrauchbar! Sad
Diese fehlerhafte unbrauchbare Version war etwa von Dez. 06 bis - Ende März 07 erhältlich. Die Abweichung kann mehrer Hundert Meter oder Kilometer betragen.
Welche Frimeware auf deinem Gerät drauf ist kann du einfach feststellen wenn man unter dem Menu Einstellungen bei System die Taste <Menu> drückst.
Daraufhin kann man die Softwareversion der Firmeware vom GPSmap ablesen.
bin heute mal wieder bei Garmin auf der Website unterwegs gewessen und hab ein neues Firmeware Update für mein GPSmap 60CSx gefundnen.
Zitat ab der Garmin HP:
Change History
Changes made from version 3.50 to 3.60:
- Correct German translation of 'delete all waypoints'
- Fix data card unlock failure when 2 cards of the same map set are used in one device
- Improve sun times for polar regions
- Fix issue where ETA in non motor vehicle modes can be unreasonably short
- Improve robustness of compass when it would appear uncalibrated until a power cycle
- Increase precision of distance measurement to the cursor on the map page
- Allow backlight adjustment on the track back point selection page
- Fix shutdown when editing Estonian Grid coordinates
- Correct daylight saving time for New Zealand
- Improve selection of the names of cross roads with NT maps
- Correct potential shutdown when viewing a vertical profile
So wie ich es verstehe, ist da nichts weltbewegendes dabei, weshalb dieses Update zwingend aufs Gerät gespielt werden müsste.
Mir würde da noch viel einfallen was man verbesseren könnte....
Es gibt wieder mal ein Firmware Update fürs Garmin GPSmap 60 CSx.
snip garmin.com
Change History
Changes made from version 3.60 to 3.70:
- Fix issue where bathymetric (underwater depth) lines would not show up in non-marine night color mode.
- Fix issue where tide page can show the wrong date.
- Fix shutdown when the day view calendar page has more than 9 waypoints and a point at index greater than 9 is deleted.
- Fix issue where tracklog setting was changed when unit was put into mass storage mode.
Hat sich also nichts getan ausser ein paar Fehlerbereinigungen.
Das bestärkt mich in meiner Meinung - Garmin wird wohl in Zukunft im GPSmap 60CSx keine neue Features mehr einbauen um sich das Geschäft mit dem Verkauf der neueren Geräten nicht kaputt zu machen....
Es gibt seit langem wieder mal ein neues Firmware Update fürs Garmin GPSmap 60CSx
Neue Ver. 3.90, vom 30.März 2009 fürs Garmin GPSmap 60CSx
snip Garmin page:
Change History
Changes made from version 3.70 to 3.90:
Added support for maps greater than 2 GB.
Oder auf Deutsch:
Unterstützt werden neu Karten grösser als 2 GB.
Lamp Garmin Exchanger: GPX-Tracks vom Android Handy direkt ins Garmin GPS 60CSx laden RedOrbiter 11 72'571 04.11.2025, 15:52
Question Garmin GPSmap 60csx Mountainbike tauglich? RedOrbiter 0 8'121 08.05.2017, 11:32
Thumbsup OruxMaps: Neue Version von OruxMaps im Android App Market für Smartphones RedOrbiter 16 86'531 30.01.2016, 10:05
  Übertragung Tracks Basecamp - GPSMap 60csx ikarus 0 8'031 02.10.2015, 21:12
Letzter Beitrag: ikarus
Question Höhenmeter summieren mit dem GPSmap 60CSx von Garmin RedOrbiter 1 10'384 26.05.2015, 18:30
Letzter Beitrag: Hans
